Quad Cortex Flashing Blue
My QC is stuck with blue lights flashing and I can’t start the device. I read about several people who had a similar problem, but I still haven’t been able to solve it with the tips I’ve seen so far.
Are you using the stock power supply? Have you tried to remove all cabling (e.g. USB, XLR, EXP, MIDI etc.) and power cycle? Worst case, please open a ticket with NDSP at support@neuraldsp.com and they will quickly get you sorted.
I’ve faced the same problem, two times with two different units.
Fortunatelly I’ve buyed from an oficial reseller who made the warranty.
QC is an awesome device, but I’m sad that is not reliable for me.
BTW, no answers from support, they just asked me to send the unit back.
Seems to be a batch problem, who knows, 00 transparency from Neural Team.
I just updated the OS on my QC this evening and now I’m getting flashing blue lights as well.
Hi.
Same issue also on my side after an update…
I tried to follow all the tips and instructions I saw on the forum, with no result.
But, I don’t know why, my QC suddenly started working again without me having carried out any special procedure.
Unfortunately, it is no longer a reliable device for me.
If the issue resolved itself, that likely was not the same issue other have had resulting in having to repair etc. Were you using a hub, OEM power supply, other things plugged in?
No, man. I have never used any other power supply other than the original. What I did was insist on leaving the blue lights flashing for more than 20 minutes and then it just started. Now it is starting at normal time, 45 seconds.
Had a used one with same issues. I think it was from early batch. They paid shipping both ways. Fixed it sent it back. Didn’t even buy it new. However, the reverb seller if ur reading this over charged me by a lot. I bought a new one too. I don’t need two so will be selling one but can’t bring myself to do it for some reason. I have never had a company take care of me this well. Ever.
So did u send it back? They’ll fix it and I guess it’s up to you to decide if you want to keep it. I’m sorry my friend. There’s issues with amps and pedals too. I still use them a lot. One amp’s crackling and one pedal is squealing. One thing is certain regarding gear, there will always be an issue unfortunately. Good luck to you. :four_leaf_clover:
I sent mine back and they fixed it.
Dan when Rabea was in Japan and Korea his last song starts with an effect I’ve never heard around 1:33. Do u happen to know what he’s using? Thank you, j
Mine flashed blue lights the next day after the update and I unplugged it and then it was fine. its doing it right now and I can’t get it to reboot like it did yesterday. I have gigs!
Email support@neuraldsp.com. I had that issue. They fixed it asap and got it back to me. Shipping paid both ways and mine was used. Unless you just got it at say Sweetwater in less than 30 days. Then they owe you a new one.
Sweetwater is sending me a new one, thank goodness.
That’s great. So don’t forget if it happens after 30 days well let me say this first. I bought a used one. Don’t let anyone tell you that neural won’t fix it. They not only were kind but paid my shipping both ways. It was a weekend and a holiday. But they got it back as quickly as they could. I love my amps but I missed it and bought a brand new one from Sweetwater. So if u have another issue after 30 days as I said email support@neuraldsp.com and they like u to keep the same email thread during the time u talk to them for that issue.
Fix: removed the back, located the retaining clip holding the SD card. Removed the retaining clip. Seated the SD card fully and replaced the retaining clip, making sure the card remained fully seated - held in place by the retaining clip. Put the back panel on. Started right up! below a photo showing the retaining clip and SD card - in the center of the close up shot. Cheers!
I haven’t experienced this issue but it’s good to know that reseating the SD card could fix it. Thanks Woodenmusic!
