QC -> XR18 Output Volume
I am using my brand new QC with the latest update and the brilliant Archetype Nolly X plugin. I split my output so that 3 goes to my power amp then to my cab. Output 4 goes to my XR18 for my IEM. Except it doesn’t. The input being sent to the XR18 is virtually undetectable unless I crank the gain all the way to +60 on the digital mixer. This simply will no do.
I have validated all my levels, cables, etc. and I am just not getting a usable output. What should I try next?
Thank you for the reply!
Yes, QC is at max volume. Outputs are validated at good levels. The XR18 is using line input. I tried using one of the balanced outputs with the same results. I will check it against 17/18 on the XR as you suggest and let you know the results.
EDIT: Same result using line. Tested direct from the back of the QC as well as swapping out cables. I am wondering if I should factory reset my XR18 and rebuild it’s mix. The QC has been updated and reset to stock. :frowning:
EDIT 2: Expanding on your line input advice I moved to try the balanced Output 1 and was able to push the gain up to tolerable levels without any noise! Problem is I still need an input gain of about +55 (my our mics are around +42 as a reference point) so this is tolerable to me. Still seems quiet but it works now.
This happens through both stock (as mentioned, brand new unit) as well as the NollyX preset I am using here: https://cloud.neuraldsp.com/cloud/u/AWMusic/preset/view/0ca42c21-573a-449b-beb3-ca87c0f35844
To clarify, this is how my preset has been modified. Original version was quiet too:
Row 3 is out on 3 (TRS) to my poweramp which runs to a speaker cabinet.
Row 4 is out on 1 (XLR) to my XR18 but requires a 55db boost to be heard at a normal level. Via XLR(1) or TRS(4) has the same result.
You mean Behringer support?
I have contacted Neural DSP support and have yet to hear back from them. Same with Behringer, I just made the assumption that my QC would be as loud as my POD Go was through the same input. Seems strange to me that the QC would be so quiet. I wonder if an active DI box would correct this?
Yes - Can confirm all outputs are in mono mode and the gain is at unity +/- 0. I think the XR18 may just need a whole lotta signal to come through. Very strange indeed. I have submitted a ticket to them to ask. I really do appreciate all of the help and fresh perspective, I’ve been pulling my hair out trying to sort it.
