Does anyone know of a way to modify the default point and set curve modification points for expression pedals? An ideal example would be the equivalent of the TC Toneprint Mash modifier window. (A default position and 5 set points along the curve for top, bottom, middle, and then the half points between middle and extreme ends.)
Might be nice to have a “Q” and a sweep parameter. Get a vote going!
Ideally you could pair the pedal to any parameter of any block, not just a particular EQ parameter.
It’s nice that there’s at least a Log/Linear switch, but I agree, ultimately the QC should be flexible enough to have an adjustable curve option as well. My only concern is that if they implement it per block/preset/scene that it gets too complicated for most users, and if it’s a single global “custom” setting it won’t be enough for everyone.
So while it’s a good idea, no matter how they implement it, someone’s going to be upset about how. I think a single additional global “custom” option is probably best though (K.I.S.S.)
