I did re-do all my live preset again, did not help unfortuntely in my case. Also after update analog delay block settings did change. I did have there slap back style delay, update did change it on regular delay trails.
Yeah some bugs was my first thought also, my delay block settings did change also after update. And repeats on those delays, did sound like out of tune. Weird things for sure.
Hi everyone I got the issue it is for sure a bug when using a midi controller sometimes not always there is a volumen increase when changing between banks and it also happens that it get frozen and it is not possible to change presets anymore. The only solution is a restart.
Well I have some updates if I use the usb c to use the nano as an interface, these volume changes occur almost every time I use midi to change presets… so something is there with the midi control programming
Aa you did find that kind of thingy. I did also try few things. To get volume back to normal, i need to press twice same midi command. Or i need to switch different impulse response. Definitely its sounds like there is some bugs, on midi commands maybe. We need some kind of fix on this one, can`t use it live right now. Too risky to get those volume clipping issues unfortunately.
I am right now in the same situation. Until mid January don’t have any gig so there is still hope. I also realised that’s it can happen that at some point NC ignore some preset changing orders and it need to be restarted
It happened to me too. More or less. At home, it happened a couple times… when I switch from a preset with wah controlled by a CC1 message through the TRS midi port, to a preset with an EQ controlled by the same CC1 message, the volume got lowered A LOT (almost inaudible), I had to switch back and again to the preset and then it was OK.
I though it was something of my controller or whatnot.
But then, it happened to me in a gig. I got with no volume in the begining of a solo… Had to switch presets quickly to get the volume back to where it should.
Those things that you´re commenting seem similar to mine. It´s maybe a bug in midi receiving in the NC?
Ok you have also problems on it, this seems like to be bug for sure. Yeah i have same things studio and live, same issues going on.
Also i have read a lot issues users trying to update NC, and they did get stuck on install process. And cure for that was removing TRS midi connection, to get pass and getting update done.
Maybe something did go wrong on Midi codes or something like that, before this update i did not get any issue on NC.
Lets hope they will look this issue and would fix it, would be nice to trust NC and using it live again.
I updated mine with the TRS midi cable on it and it took very long but no issues with the update… but yes it does this same bug with the volumes. I only experimented them in home studio and once in a rehearsal. Anyhow difficult to trust right now for gigs so I am getting my analog pedalboard ready again until the big is solved.
Yeah its difficult to trust right now on NC, we need definitely that fix soon as possible. I did write them directly on support, also i did share clip to them about that issue.
If you have some extra time would be nice to get more reports on them, about this issue we could get that fix soon as possible.
