Previewing 3rd party IR’s is simply exhausting!
When adding a Neural Capture, it’s possible to tap on a capture to preview it prior to committing to it… why isn’t Custom IR selection the same?
You have to tap change device, tap the cab, scroll to the bottom and then tap Load IR and then when you select one, it loads immediately… this is seriously tedious, whereas it would be great for it to have the same preview behaviour as the Neural Capture loading…
