Pre amp pedals
Hi. I just bought a crazy tube circuits Hi Power and was wondering how you would run it as a pre amp pedal? Would it be as simple as just running an IR after it?
Sounds like a pedal you place in front of the qc to me.
“…slams the front end of a British amp with legendary headroom in order to make your guitar tone shine like the sun.”
From manual…https://static1.squarespace.com/static/55ae0893e4b0f896046f0f37/t/65645ed29537da663221af12/1701076695654/HI+POWER+MANUAL.pdf
Yes, you can use it that way. It just depends on what other effects you wanna use within the QC and where you want your preamp pedal to be in the signal chain.
If you don’t wanna add any effects before the it, simply put it before the QC.
If you do want to add effects before it, put it in the loop and add loop blocks on the QC.
If you don’t need your FX loops for anything else, I find it useful to have my pre-amp pedal in a loop, meaning I can turn it on and off with scenes/presets, rather than having to tap it seperately (if it was in front of the QC).
