I am currently building my first Pedalboard setup and I am trying to keep it as minimalistic as possible by putting my Quad Cortex and DVP5 Expression Pedal from Dunlop onto a Metro 16 Pedalboard. Since the Dunlop Pedal doesn’t require any power it is only the Quad Cortex that needs to be powered. I am currently looking for a Power Supply which will fit underneath the Metro 16 Pedalboard and has everything already built into it so that I’m basically only required to have just a single cable without a charger brick in between running out of my Pedalboard directly into an outlet. I am familiar with the CIOKS power supplies, but was hoping maybe for a more budget friendly option.
Thank you already very much in advance for you answers:)
I could use the original power supply, but I would like everything to be tucked underneath the Pedalboard with just a single cable sticking out of it without the bulky brick. Don’t ask me why, doesn’t have anything to do with functionality, just sheer aesthetics .
Sweetfoot makes a good power supply and will make it to your specs. I was the first person to get one for the QC and still works great. I have even older ones for HX stomp and HX Effects pedals and they still work great.
That is an interesting Freudian slip there, and I’d definitely agree on the “mashed” part.
He mashed the heck out of the 2 defective ones he sold me.
Can’t recommend
If the aesthetics of the OEM wall wart adapter are not to your liking and you don’t need to power anything other than the QC, then you don’t need a pedalboard power supply like Cioks. You can simply buy a 12V in-line transformer adapter with IEC wall cord outlet and 2.1mm barrel connector for the QC. Best to buy 3.0A or greater (even though a 2.0A would suffice) and if you can get it with center negative that would be directly compatible with the QC, otherwise just add a reverse polarity adapter. Since you have a Metro 16, you need an adapter with max height of 1.25 inches (I have a Metro 16 also) and you can simply attach the transformer to the underside in the same way that you would attach a regular pedalboard power supply (Duo-Lock, small brackets, zip ties, etc.). Look for something like this:
