Plugin Presets to Scenes
Has anyone found an easy way to create multiple scenes from different presets in the same plugin? It seems when I load a plugin preset all the blocks are in the same order, while the parameters and blocks engaged are different (to be expected).
Seeing as how the functionality of scenes would already handle engaging switching blocks, I think this would be a great future feature, so users don’t have to recreate each scene block by block, parameter by parameter, etc.
I don’t think the feature is availabe, so atm you can only achieve this manually. It would be so helpful to have this feature, so you easily could assign different plugin presets, to your scenes on QC
