A good example, I follow the amps / drives / preamps with an 8 band parametric EQ, with wildly different settings for each scene.
There are times when it is beneficial to copy a whole set of EQ settings from one scene to another. Or the settings of a reverb block. Or whatever.
Or copy just the settings from one scene from one block to exactly the same block on a different preset, also on a specific scene.
This would save me a lot of time and effort as I’m constantly iterating all my sounds to be a little better, and often one scene specific setting I improve a bit would be good in many other places as well, other presets, other scenes within the same preset.
Going back and forth and copying the numbers over one parameter at a time is painful and a needless waste of time, this feature could be implemented with UI tweaks.
