Pitch Shifter can't be set to different value in different scenes
CorOS Version: 2.3.0
Describe your issue:
When I add pitch shifter to the frid and I want t ocreates 2 scenes, one with pitch coarse -1 and one with pitch coarse +1, the values are not saved. Both scenes will have the same value.
  1. Create scene A with pitchshifter pitch coarse -1 and save.
  2. Create scene B with pitchshifter pitch coarse +1 and save.
Both will have smae +1 value now.
Check and see what your behavior is configured for and make sure you are long pressing the parameter(s) you want to set for each applicable scene. You will see the ABCD icon next to the parameter once its successfully enabled for scenes.
That is all fine…it is assigned to scene mode…Does it work for you?
Works for me. I have one scene with -7 and one with -8 in one of my main presets.
Yes, I have used similar parameters without issue.
Screenshot 2024-02-19 115209
Make sure the small ABCD square icon is showing for the pitch-coarse parameter. Also, confirm that your QC is in Scene Mode (or hybrid)- those really should be the only 2 issues that could be making a difference here.
This helped me. Thanks. The. ABCD icaon was active for the pitchshifter but NOT for the pitch-coarse. Great help
Awesome! Figured it would be a quick fix.
