Hi everyone. I have my main preset with only one amp+cab (stereo output). When I track in Logic, I realize that the two tracks have phase inverted.
Why? Than, if I reverse phase in one track in Logic, the sound it’s ok.
I don’t understand why I have this problem.
Can you help me? Thanks
Hello. Do you have the same out-of-phase state when using the same amp and cabinet, going to direct to your monitors (not in the DAW environment)?
Stereo cab blocks in the QC have a phase invert option built in, in case you need it. Ultimately it’s not a big deal whether you apply phase invert in the block, or in your DAW.
Also, we just got the new Phase Doctor block (with CorOS 4.0.0) that has even more options. You can use it to adjust for phase shift that’s less than 180°.
Hi, thanks for your feedback. I found the problem: it’s due to my UMC404. I tried to play with USB and headphones outputs, and phase it’s perfect.
Thanks again!
