Phase inversion on the second output
Adding an option to enable phase inversion on the second output of a stereo output pair would be a highly useful feature, particularly when the outputs are used with two separate amplifiers.
I’m not at my QC at the moment but you should be able to use a gain block at the end of one of the signal chains to invert the phase. I agree that phase inversion should be an option on the outputs but at least there’s a workaround available.
Thank you for your comment Mr. DiffractionCircuit!
If I use two different lanes for separate mono outputs, your suggestion works fine. But if I use stereo pair 1 & 2, for example, as FOH lines and stereo pair 3 & 4 for amplifiers, I can’t find a way to invert the phase of just output 3 or 4.
Unless there’s something I’m not understanding right now.
