Do any of you know what Petruccis gear/rig was on Six Degrees of Inner Turbulence? I think his tone is amazing on that album, especially that riff on About To Crash (Reprise)!!
I believe he used his beloved IIC+ and in that regard, what IIC+ capture do you find the best to capture that Petrucci tone?
To create a John Petrucci tone from Six Degrees of Inner Turbulence on the Quad Cortex, you’ll want to combine a few key elements: high-gain amp tones, tight low-end response, a powerful midrange, and ambient effects for spacious solos. Here’s a detailed breakdown of the blocks you’ll need to replicate his tone:
1. Input Block
Ensure your guitar is set up with high-output pickups, ideally a humbucker like the DiMarzio Crunch Lab (which Petrucci uses). Input sensitivity should be set so your signal is strong but not clipping.
2. Noise Gate
Threshold: Adjust to eliminate noise from the high-gain settings, but don’t cut off sustain.
Attack/Release: Fast attack, moderate release to keep your signal tight during rhythm playing.
3. Compressor (Optional)
For clean or slightly driven passages, a compressor can even out dynamics, providing more sustain.
Type: Studio VCA or Optical compressor.
Settings:
Threshold: Around -20dB.
Ratio: 4:1 or 3:1.
Attack/Release: Medium attack, fast release to keep articulation.
4. Overdrive/Boost
Petrucci often uses an overdrive in front of his amp for tighter, more focused distortion.
Suggested Pedal: Tube Screamer or Horizon Devices Precision Drive.
Settings:
Gain: Low (to tighten the low end).
Tone: Adjust to taste, usually set bright.
Level: High enough to push the front end of the amp.
5. Amp Block
Amp Model: Use a Mesa/Boogie Mark IIC+ or Mark IV model (Petrucci’s go-to amps during Six Degrees of Inner Turbulence).
Settings:
Gain: High (to get a saturated tone).
Bass: 3-4 (keep it tight, Petrucci likes a focused low-end).
Make sure to fine-tune based on your playing style and the specific guitar you’re using. Petrucci’s tone is dynamic, so use your hands to vary pick attack and get the most out of this setup!
