Per-Output IR/Cab Bypass
Would like the Quad Cortex to have an output-level option that allows an IR/Cab block to be bypassed for selected physical outputs while remaining active for others.
For example, I may want:
* Main Outputs → IR/Cab enabled for sending a processed signal to a PA/FOH system.
* Output 3/4 → IR/Cab bypassed for sending a signal to a real guitar cabinet or power amp.
* Both outputs to come from the same preset/signal path, without requiring duplicate signal chains or separate presets.
Ideally, this would work in a similar manner to the Nano Cortex’s per-output IR/Cab bypass functionality.
This would allow more use the splitters to be used for other reasons like Parallel Devices and such.
Thanks!
Hello and welcome. This is already highly requested, go here:
Welcome @Siknu
Please utilize the search function prior to submitting new feature requests. Thanks!
