There are lots of requests for more effects slots on the nano, or more flexibility for what goes in each slot, or the ability to have two capture slots. I’m thinking that hardware limitations might prevent a lot of this.
Something that might be easy though, would be to have an option to replace the IR loader with an effect slot, even if it’s just EQ. I haven’t found any other requests for this, so thought I’d post. This option could be used with a cab capture, when the IR slot would otherwise be turned off.
As a kind of workaround, I’m going to try loading in a blank IR, which doesn’t affect the sound, so that one can at least use the low and high pass filters in the IR loader. Would be great not to do this and have a proper effect slot there though!
