Just noticed L&M here in Canada had the SP1-ND in stock, I’m just wondering if I need 2 TRS cables or just 1 to connect to my QC?
It depends on your use case. The toe switch function connecting the switch output to the second EP input can be unconnected if not required. If you want that function, then get two TRS cables. I would just to be able to use that function if ever wanted/needed.
Will probably be using it mostly for wah, but the toe switch will come in handy for that. 2 cables it is. Thanks!
Glad to help! ![]()
