Noise problem. On all captures.
Post a link to your preset and we can check it for you.
Also for everyone here, when listening from the USB output through my PC, this hiss is always there at a constant volume even when not playing. When listening through the TRS output, the hiss is only there at certain input volume ranges and acts like the clip I provided earlier where the volume of the hiss seems to increase until a point and then cuts out. Seems like when using the TRS output it does something to limit this noise in a weird way that results in the odd hissing sound so seems like a hardware fault or a software bug. Would love for this to be fixed in another update if it can be replicated and if it’s even fixable because this is really the only issue I’ve been having with the device. If I can’t fix this issue then I might try and get another unit and see if that fixes it.
Will post when I’m home. Really appreciate the help.
My noise issue is definitely capture related, probably to this specific capture but haven’t tested others. It’s not apparent on any stock devices.
I have one posted that I sent to tech support. User name is Bigrockandy and the preset is “Hiss Noise”.
Did you find a fix for it?
Sorry to revive a fairly old thread, but this thread mostly closely resembles the type of noise I have. A hiss that comes in when sustaining a note (when the note starts to get quiet). Did anyone ever figure anything out? Is it fairly normal?
I’m on 3.0.1 right now.
Maybe this helps:
Pete Thorn said (some time ago) in a video that you need a “line isolator” to avoid noises when capturing with QC.
Nothing very expensive.
I’ve got one but haven’t tried yet. Palmer Line Isolation Box PLI-01.
If I find the video I’ll put it here.
