I tried but nothing is happened. but now I don’t have problems.
If you have a single coil pickup then make sure your guitar is properly grounded internally.
I had the same problem with my Stratocaster but not my Les Paul.
Single Coils are noisier by design anyway.
i would check that as well, might be loose ground wire on the guitar. can happened
In the other thread you posted in, you indicated you are using the Scarlett audio interface etc., has that been the case all along? Just curious, as that would indicate other variables with your noise issues. Thanks!
Ey. Yes. I had noise everywhere. Scarlett, frfr, and usb connect.
