CorOS Version: 2.1.1
There is no sound when creating a new patch unless adding an effect after the speaker block. Is that normal?
Any chance you have the Mute/Bypass selected under the context menu (three dots)?
Update: Nevermind, probably not the issue if the sound is coming back after adding an effect block.
No, I have not touched that. On a second thought probably the headphones are failing or dead.
Wouldn’t be the first time. Sometimes it seems like some manufacturers go out and pick the thinnest most fragile wires they can find when it comes to headphones. ![]()
At least this should be an easy issue to test with other headphones or monitors.
