Hi @Sergio. First, disable the input you’re not using. Then make sure to turn off “Direct Monitor” at the front of your audio interface.
It works. I had activated 2 input instead of only one
Thank you Gonzalo.
Some of the advice mentioned here worked to get the input into the program however I still was having issues with getting audio output from my computer speakers. Here is how I got it to work:
Hope this helps
Hi, just came across this thread. Im alos experiencing this same issue, where it works in my DAW but not as a standalone. I’ve tried the given advice to untick the input i’m not using, but it doesn’t elet me do that. as you can see, the appearance of my preference window differs to the one posted in the comments
The screenshot you provided appears to be the DAW audio settings/preferences. I would match the settings in the plugin matching the screenshots provided above and start there.
tried everything and still no joy, although it works in the DAW with no issues ![]()
in the plugin itself when using it as standalone, it doesn’t let me change the inputs
Post a screenshot of your settings for the plugin.
That is for NAM (Neural Amp Modeler) which is not affiliated with NDSP. You might actually find support in another forum but unfortunately that is not an NDSP product. Good luck!
