I had an odd problem. When I use the 4CM method as recommended by Neural, things all work perfectly when I’m using the QC for effects only, and using the JCM800 preamp for distortion.
I was hoping to be able to use other models though on occasion. I tried to build another patch, with the pre-amp of the JCM800 selectable via the fx loop of the QC (so out QC send, in amp guitar input, out fx send of amp in FX return of QC, then QC goes out output 3 into amp FX return)..I thought that way I could engage the JCM pre-amp when I wanted, or if the QC loop was off, the signal would go straight out ouput 3 into the fx return power amp and would use other amp models into the power amp.
The problem is the volume of the amp models have to be turned WAY WAY down - like -30db+, etc - it’s like going into the fx return just has full head volume when it hits the power amp without the master volume changing it.
Is there a different way to wire this? Or is this just an issue with a serial fx loop return of the JCM being not controlled by the master volume on the JCM?
