Hi guys.
In need of some advice. How do you transfer presets for example the slo-100x to the quad cortex. I’m not the best with things like this so any help is appreciated.
Hi guys.
Thanks. Just tried and this feature is brilliant. Some of the presets for the SLO-100 are brilliant and exactly the sound I had in my head.
Hi, this is what I found worked for me.
I had the original and the X version of the plugin. I had copied a custom preset into the X version but not saved it in the X version, After I renamed it and saved it in the X version, I was able to transfer it. I hope that makes sense…
Hi thanks for the reply. But I’m downloading users presets from the forums. When I go to add it to the plug-in it won’t load it
What does it say when you click on the “i” icon in the error message?
It states "Legacy preset Format please resave it by using the plugin X version
Just figured out what you mean. How do I save it to the X version?
Thank You
WIll
You need to open it in the X version of the plugin and then save it thru the Preset manager, the area next to the Preset name
