Hello all, I’m wondering if the neural factory amp captures on the QC contain the speaker sound as well, or I have to place a cabsim after them?
Cab Sim after amp block
Thank you, that’s obvious. My question was about if you put a neural capture on a row, should you leave it alone or you have to put a cabsim after it?
The Factory Captures that are made with a cabinet specify so in their title. With all the others, you should use a cab block in your signal chain. This will be made more clear with the upcoming changes to Neural Capture and the file manager.
Thank you VERY much!
