Nanocortex volume
Hi everyone, I just got the nanocortex and very happy so far but I think that the overall volume ( level pot) is in general very low… Someone has the same kind of issue ? Is that normal ? This is happening with the factory presets and captures … This is why I think it’s maybe not normal. I could rise the volume of the capture or the IR but I m just not Shure if that would apply some gain when is connected to the front house in a gig situation. I will appreciate some comments. Thanks !!
I will update myself this question I also discovered that the input level from the DI signal using the NC as recording interface is very low. There is an option to set the input level?
I was experiencing the same.
I could not find any proper solution listed but finally found a solution.
After connecting Nano to computer before opening your DAW go to System Settings… navigate to Sound. Look for the Output & Input and Click on Input - Nano Cortex - Increase the Input Volume.
This looks much better.
I will try that, in general I must say that with the plugins there is no problem because we can rise the input level but to edit it can get tricky not seeing the signal properly
