It would be really useful if the QC could not take up an entire parallel secondary path and instead allow smaller combinations of parallel blocks or a single parallel block to be available. For example, if you wanted to use two different drives or clan/drive combination in parallel going into a mono amp, but then be followed by by a parallel combination of stereo reverb and delay. Yes, you could accomplish this if using all four lines, but depending on other routing (for example a bass on line 3 and a vocal on line 4 for live scenarios) there are lots of situations where this would be useful.
That’s of the things I wish the QC could do. Let us split again after a merge. It’s just ridiculously inefficient to sacrifice a whole lane for a single block.
There is already a request for this.
Please remember to use the search function prior to submitting new feature requests. Thanks!
