For anyone familiar with the Morningstar FX midi controllers the possibilities for a single foot switch are exponential when you can have different messages for short or long presses, or for double taps. Or for 1st and 2nd presses.
The most common is the tap tempo button that turns the tuner on when you hold it for longer.
It would be a delight if one foot switch could be one drive pedal for the first press and another for the second press. Or would turn on both drives with a quick double tap, or off if you held it for a second.
Exponential possibilities.
Cycle between two drives
Cycle between two delay times
Cycle between two amps
Having at least a long press function would make the QC ten times more useful for live performances!
This was a total game changer for me when I got into my fractal units.
I absolutely love the QC weight, size and UI but adding an external midi footswitch really starts to defeat the advantage of size, weight portability!
I feel you. I currently have extra pedals on my board because of the limited midi on the QC. If they expanded it to be similar to most other modelers I could use it in place of most of my board. Currently the QC is just one piece rather than the centerpiece of my setup.
