Mode for monitoring input and output levels for each block
This is a very useful feature. Very often guitarists have problems because they can’t track overloading or insufficient amplification inside the chains. This is what it should look like:
QC - monitoring
Horizontal meters above blocks have a slight drawback, they are difficult to estimate the relative change in loudness between blocks. All the same, it is better to have vertical meters, they show well how the volume changes from block to block:
I also think that the meters should not always be visible, since they have some computational load, but the clipping indicators in the form of red dots should always be displayed, regardless of whether the monitoring mode is enabled or not.
  • I think the best place to activate the monitoring mode is the button on the block editing panel. This is handy when creating and editing chains, also in case of detecting clipping using the dot indicator, you will need to open this panel.
  • the clipping indicators should reset when monitor mode is turned off.
  • It is important to add a reset button at the top of the screen, because even with the correct setting of the levels, occasionally there are signal bursts that can be neglected, but they light up the indicators and opening the edit panel to reset will be somewhat tedious
I’m not sure meters are that important for blocks. The chance of digital clipping primarily occurs at the input and output, where the A2D and D2A converters have limited dynamic range. Once inside the Quad Cortex, its likely there’s plenty of digital headroom. As long as you don’t go crazy with accumulated gain, and make sure the input and output aren’t clipping, then you should be OK.
Where block metering would be useful though is in things like compressors and noise gates in order to see the gain reduction.
Hi @jamsden :slight_smile: That’s a great idea! I was thinking about the same thing when I subscribed this morning and opened a Topic for GR metering before reading your comment, hopefully you hadn’t already made one :slight_smile: Well, let’s hope it gets implemented soon!
This would be very useful for manually levelling amp and capture blocks against one another when creating multi amp channel presets.
Yes please! I get so screwed up with my levels aside from chain input and output.
As a first step it would be very useful to have small level indicators for all four output blocks (maybe similar to the noise reduction indicator in of the input block), ideally with a numeric dB value option. I’m adjusting the output level of my presets to be at around -12dB maximum. It’s quite annoying to always go into the output block by touch&hold in order to check the level while building or modifying patches.
Great idea but I just want to know what app the OP used to create the graphic for their feature request? Nice job! Deserves votes just for presentation :grinning:
YES, this would be amazing for gain staging and those of us who constantly worry about clipping in the grid
Voted. I don’t particularly care about the execution, but now that we’ve seen the gain reduction metering added to the compressor blocks, gain stage monitoring across the board is the logical next step.
+1
Great feature.
This is super important!
Just did a test, because I was curious…
I filled Row 1 with Gain blocks, each set to +12dB (so 96dB total gain).
I filled Row 3 with Gain blocks, each set to -12dB (reversing Row 1).
I then adjusted the input gain to get my signal as close to 0dB at the input as possible, but could hear no clipping at all until I pushed the input gain so far that the input of my audio interface started clipping instead.
A pretty rudimentary test, but if the unit has more than 96dB internal headroom, I really don’t think anyone needs to worry.
