Correct gain staging is a must when we compose new presets to the QC. This would be much easier if there was a signal level indicator in each blocks input and output. How should it look like, idk but UI-designers surely know how to do it.
There are a few similar requests with many votes already. Here is the 1st that I came upon using the search function: Mode for monitoring input and output levels for each block
If this is what you are looking for, let me know via DM and I will delete your request/post.
Closed per OP’s request.
