MIDI Thru Not Working?
Hi there, I’m honestly not sure whether I’m configuring the QC wrong or if this is a genuine issue.
I have my QC hooked up to my computer, where I use Logic Pro X, via USB. I also have it hooked up via MIDI Out to my Boss SL-2 pedal. Long story short, it’s able to receive MIDI Clock from Logic Pro X or send MIDI Clock to the Boss SL-2, but I can’t get it to transmit the MIDI Clock all the way from Logic to the Boss SL-2.
The following configurations work:
  • Send MIDI Clock = Off: QC receives MIDI clock from Logic, LED light turns Blue
  • MIDI Thru = Off and Send MIDI Clock = DIN: QC sends MIDI clock to Boss SL-2, LED light turns Red
I would assume that turning MIDI Thru to On would allow the QC to transmit the MIDI Clock from Logic to the Boss SL-2, but that hasn’t worked at all - instead the light continues flashing Red.
Am I doing anything wrong here, or is this an actual technical issue?
