MIDI mapping issues in X plugins+Ableton
I’m having big issues with the X version of Archetype Petrucci and Henson.
I’m using a Behringer FCB1010 with the UN02 chip.
I’ve never been able to map MIDI successfully inside my Archetype plugins (Petrucci and Henson). My MIDI controller works fine, the computer receives the MIDI messages, Ableton Live sees them too. However, I can’t ever get the “learn MIDI” function in the plugins to work.
However, I can make MIDI work using Ableton Live’s built in MIDI mapping feature.
However, this doesn’t work well in Petrucci X. It takes 3 presses of a switch on the FCB1010 before the plugin starts to react to the switch. This happens every time that I change patches too.
This makes the plugin very cumbersome to use with my footswitch.
This functionality worked absolutely fine in the non-X versions of the plugins, even if the built in “learn MIDI” function never worked. However, the update has made the plugins very difficult to use with my footswitch.
How can I make this work?
Im having this issue too only with X version plugins. The new midi learn function just doesnt work for some reason.
I got it working, using note values as DD guitars mentioned. Also needed to set up separate MIDI tracks in Ableton Live, making them send MIDI to the audio track with the plugin.
