Hello guys, I’m trying to control the Nano with a Bridge6 via USB-C but seems not working.
I check midi channel (1 in both devices) and I assigned PC from 20 to 25 in all the 6 switches just to change preset on nano but it doesn’t work.
I checked the manual and should be ok…
Maybe I forgot something???
P.s.: the same controller works with my Dwarf in usb-c mode, on QC and Axefx3 too.
I tried with 2 USB-C cable and I also tried with a Midi cable-trs type A (tested!), sending program change on the same midi channel (1).
I checked that the midi controller send correct messages with another device.
I tried sending PC via usb-c with LOGIC and it works but I can’t use il with my controller midi… but it works with other devices and I tried 3 type A cables!
edit: shooting troubles atm, might have been my fault
so yeah, same here. no idea why it doesn’t respond to program change messages. tried with helix stomp, switching through from 1st preset. nothing happens on the nano
Tested with Ampero control , USB-B to A cable ( a printer cable ) + Apple’s USB-A to C adapter
the cable + adapter can transmit fine to logic pro running in mac mini. NC did not receive the commands . however , adapter works fine with printers and external CD …
switched to MacBook Air & pocket midi and everything worked fine with normal usb-c cable.
NC would receive C messages properly.
the I programmed QC to send midi PC messages , and connected the printer cable + adapter to MacBook usb , and lo behold , i can see pc changes in pocket midi’s midi in monitor . Nano cortex
does not respond though ( using omni or dedicated channel input )
Same issue here. I am working on a midi controller project and nanocortex doesnt seem to accept any signal without ground of the controller and ground of the NC connected together. Why would Neural use such a non-standard input ? I believe the whole optocoupler isolation idea is about grounds not having to be connected..
ground is always on the TRS sleeve. TRS A and B versions only alter where data and power go between tip and ring. The Morningstar link above does well to show in the few instances where sleeve ground is not needed
also, it’s very well documented USB midi only works if the controller can operate in host USB mode (many cannot), otherwise you will need to use the TRS input.
