Microphone in the room
Is there a possibility to place a microphone in a room a long way from the amp in QC?
I think fractal got that.
D
Would an empty ir (pg2) with room mix 80-100% work?
There’s a room reverb in the IR loader I believe. Maybe also in the cab sim block also. That is gonna be a great option/same effect. No need to load a second IR block or anything
I’m presently capturing microphone models from the Slate software to see if they make much difference in a vocal chain. I suppose you could put one on a parallel lane and put a reverb with a long pre-delay on it before the mic model to see what effect it has
(edit: I just tried this and it’s pretty dang cool. I’ll make some captures available publicly soon)
