Microphone axis control
Into the cabs block would be nice to have a control over the axis of each microphone facing the speaker. The value could be referred in angle degrees, where 0 would be straight in front and 90 would be completely sideways.
That would require more IRs etc. Each position, level etc., is a unique IR etc.
You might have to rely on your own IRs to achieve that.
I understand that and it probably (I don’t know) be a big effort to realise, but mine it’s just a suggestion to make the miking process as realistic as possible.
I totally agree with this feature request! it would be really great to have this configuration… it’s also present in some other modelers (cheaper than QC) and can make the cab configuration more versatile to create more sounds
Hope someone from Neural team will read this topic :smiley:
NDSP reviews feature requests frequently and if there are a lot of votes, it may get implemented. This request has 1 vote currently :slight_smile:
yes, it’s mine! :smiley: I was opening the same feature request. luckly I searched before to write and found your topic… I’m sure that if I will open the same topig someone from the team will close it because your is still open… keep fingers crossed
