People make captures of amps without a cab, captures of amps with cabs or IRs “baked in”, captures of pedals, captures of amps with drive pedals “baked in”, etc.
Would it be technically possible to merge, let’s say, 3 blocks (pedal capture, amp capture, IR) into one capture block? Merging an amp capture with an IR shouldn’t be a problem since IRs are basically static high resolution EQs.
Possible benefits of capture merging could be lower latency after merging, fewer occupied block spaces on the FX lanes, maybe less CPU usage, …
Maybe not a highly required feautre, but what do you think?
