Imagine making a preset. Something like a Plexi pushed with a Klon and bit of EQ. Wouldn’t it be nice if it could be auto-captured and turned into a single bloc?
That would be nice! Especially when messing around with captures, as they are very heavy on the cpu.
I like having captures of single devices to be able to combine them as I want but that is quite limited due to the load on the cpu. Being able to set up the sound I want and then “freezing” that sound to a single capture would be extremely helpful.
Backed! Would be hugely helpful imo
Definitely would be nice. A capture eats less DSP than an amp w/cab and some pedals… My vote!
Just saw that there already was a topic on that. I leave my post here, as it has another point why this would be a great idea:
It would be great if there would be a feature to sum multiple blocks into one capture as you could already do with a second QC. This would save dsp, blocks on the grid and drastically reduce the time to capture all channels of an amp including boosts by OD pedals and different speakers etc.
Example: I captured my Suhr Hedgehog. This amp has 2 channels in the preamp with adjustable bright and mid boost and 3 modes in the poweramp. To capture every combination, I would need in total 30 captures. With the self capture feature I would need 8 captures and could combine everything else within the unit, drastically reducing time.
I had an idea similar to this, which was to create a SNAPSHOT of a group of blocks. Your idea combines the blocks into a new capture, which would free up GPU and space on the rows. Brilliant!
As A guy who currently does this, I 100% guarentee I would use it and OFTEN. The results are great and this functionality would make the QC 10x as flexible and enjoyable to the user.
All that would need to happen is to be able to assign other inputs and outputs are active during the capture process, and plugging the QC into itself.
It seems to be a very good idea.
Is it possible?
This would be so amazing!
One potential wrinkle is that the DSP necessary to run the preset is the same one used for making the capture. This could be addressed locally by just biting the bullet and allowing these captures to take longer than normal, as proposed here. Alternatively, since Neural DSP already has the infrastructure to process V2 captures on the cloud, these could be done also on the cloud, either as V1 or V2 versions…
Borrow a friend’s QC and that should work.
It can be done with 2 QC, right?
I don’t think it’s possible QC capture itself.
That’s not the point of this feature request.
As @felher.c described, there may be technical reasons why internal capture cannot be done, and that’s why I personally have not voted for it.
If it can be done internally, I imagine it would look something like putting certain compatible blocks (overdrive, amplifier, EQ, and/or cabinet) on a row together and executing a capture command from the settings menu for that row.
My assumption is that captures use the same audio engine, as playing live.
But it sure would be awesome if a capture like this were possible ‘in the box’ (with no additional A/D conversions).
This reminds me of growing up in ‘old fashioned’ studios, before unlimited tracks were a thing. Having to submix tracks so you could free up tracks to record more layers.
