Looper Y - Single Switch Looper
Please, just add a single switch simple looper:
  1. ability to choose order (rec → play → overdub or rec → overdub → play)
  2. if a loop is playing → long press → UNDO /REDO
  3. if a loop is playing → double tap → STOP (PAUSE)
  4. if a loop is paused → single tap → PLAY
  5. if a loop is paused → long press → ERASE
  6. loop playback bar always visible (2-3 pixels height on the bottom) without needs to enter into a dedicated screen.
  7. all the features should be controlled via single switch in stomp mode / hybrid mode or via dedicated midi CCs
  8. Bonus request! Press + long press —> fade out!
like ANY SINGLE SWITCH LOOPER IN THE WORLD! :tada::tada::tada:
Is this the same request?
No it is not the same.
The request match only the point #6 of my list.
In looper x you can’t set the action order, you can’t delete a loop and you can’t assign all those function to a single switch (internal or external to the unit)
Using midi cc you need at least a 4 switch midi controller and you need to know which switch you have to press for rec/play/overdub.
Without the looper screen opened, you don’t know the “state” of the looper, so you don’t know if the looper is in “play” mode or “overdub” mode.
With a single switch and a “bar” on the screen, you always see the loop so you don’t need to guess the state.
This might help as a workaround for now
