Looper X Pre-roll and Recording Length don't work until Quantize parameter is toggled.
I think I’m among the few on here that depends heavily on a looper – this issue causes a lot of problems when I perform.
CorOS Version: 4.0.0
Describe your issue:
Any preset with Looper X where I’m trying to use Quantize, Pre-Roll, and Recording Length features, the Pre-Roll and Recording Length parameters have no effect until I change the Quantize value from the original value in the preset.
  1. Create a preset with Looper X Quantize = 4, Preroll = 1 bar, Recording Length = 2 bars and save.
  2. Go to a different preset, then back to this preset.
  3. Hit record in Looper X - there will be no pre-roll, and the recording will not stop automatically after 2 bars.
I expected this to happen:
With those preset setting, I expect a pre-roll of 1 measure, then the Looper X will record 2 measures and start playback automatically. If I toggle the Quantize parameter (say, change it to 3 and then back to 4), things work as expected.
  • Here is a video of the issue: https://youtu.be/T5CMKF5TE3E
  • If I toggle the Quantize parameter to a different value and then back, the Pre-roll and Recording Length functions work as intended.
Same here! And thank you for sharing this workaround! I always though I was too stupid for that looper to get it to work because I remembered it working correctly but couldn’t get it to, again.
Please, NDSP, fix this bug!
Yeah, same thing for me too, really annoying…
