Leveling the output across all preset
Hi,
Is there any method to have all the presets set the to the same output level without having to manually tweak it in the amp settings. Cause on preset with a lot of effects and different routings it implies to rebalance several units which can be quite tricky to do.
You can use the QC output meters to balance the levels across patches. Note however that perceived loudness also depends on the tone. So you should verify the settings by ear too.
