Has anyone recorded or documented the gain/output levels of the different amps/devices in the QC at their default levels? I’m working on gain staging my live presets to keep levels steady and am trying out different amp models in the process, but it’s tricky to keep everything straight when some amps have radically different output volume and headroom levels than others.
Example: I have a preset based around the 100 watt Mesa Lonestar (normal) that’s a clean, Fender black-panel type sound, but when I switch to the amp model of a Fender Twin Reverb in the same preset, the output level drops dramatically. Plus, I can’t seem to find a way to make the Fender model get as loud and clean as the Mesa model at the same output level without hearing some grind from the amp model or some distortion from the output.
Has anyone listed out the default output levels for the QC amps for comparison, or any easy way to compare the relative headroom of different QC amps?
