Hi all,
I tried to do an recording latencycheck with the QC. Just like I do with all my audio interfaces. When doing this with the UAD Apollo, I connect in1 with out 1 and insert the I/O module from the utilities menu set the I and O and ping it, which gives me a latency of
Now when I try to do the same thing with the QC I get no ping and no value i.e. nothing is happening when I press ping.
What are you guys using in the logic audio prefs ?
I need this because then I can, as I do with the apollo , compensate for it in Logic and know that what I played is where it was played and not X ms later…
cheers for your tips.
Z.
What I meant is do you have a preset with an empty line running from input 1 to the output? Do you get sound in the present you’re running if you connect something on the input?
