My screen after newest update seems to flicker just a bit.I just purchased this and am totally new to this.I attached a video.https://youtu.be/yYWUcIcExjQ?si=_bBk0s8zdkPFNUAR
It’s hard to see any flicker on your video. Have you tried lowering the brightness a bit? It looked like the preset name might be fading a little brighter back and forth but everything else on the grid looked fine so not sure, it could just be the lighting and or your camera. You could try a factory reset and see if that resolves things. Ensure you are using the correct power supply (12v 2A center-negative) etc., worst case email support@neuraldsp.com and they will get you sorted or return to your seller for an exchange etc.
Thank you my friend,I will try what you suggested.I also emailed support.
No worries and good luck!
