IR length trick (to get longer IR with QC)
This IR length truncation/limitation has been bugging me for a while…
Found a solution that works for me :
  1. Created a copy of my cab IR and removed the first 20ms of the audio (with Logic pro, or whatever DAW)
  2. Loaded the original IR as is on the first slot of a Dual block
  3. Loaded the copy (with the first 20ms removed) on the second slot and added 20ms of delay…
Had myself 40ms of IR.
I guess you could parallel IR blocks and repeat until QC hardware limitations are maxed…
Just thought I’d share…
Plugins have longer IRs as quad Cortex.
I’m thinking to the future plugin compatibility…
IRs finally longer in QC?
I Hope so…or plugins in QC Will play slighty worse.
Crossed fingers
Longer IRs are and overall benefit for qc
