IR in plini X
Where can I locate the IR folder for archetype plini X? It supposed to come with “thousand of IR”
When you move the mics on the cabs, the plugin choose the right IR from the ‘thousand of IR’ baked into each CAB/Mic combo.
Those IR are not available as separate files, but are (kind of) hidden into the plugin. You can’t extract them and use them outside of the plugin.
