Integration of backing tracks
Hi dear Neural Team.
I’ve been using the TC Voicelive extreme 3 for years. This allows me to import backing tracks. I can use these tracks to build my sound automation on. Integrating and playing tracks would be a valuable feature for me. There are also plans to integrate vocal effects more. A harmonizer on vocals in particular would be fantastic.
Best regards
Florian
Welcome and please use the search function prior to submitting new requests.
Here is one for playing backing tracks etc:
If that fits your request, just make a note to delete this request and it will be done shortly after. Thanks!
I’ve been requesting the ability to save loops on the QC for a long time, which is effectively the same as having backing tracks on the QC: Headrush have had this ability for ages, and I think NDSP are really missing a trick not introducing a feature like this. Bottom line is you can post here and add Feature Requests but nothing with NDSP happens quickly.
I’ve even picked up a Headrush Core the other day, just to see how useable the Practice Tool on it is. So far I’m really impressed; you can save loops to the looper library (it’s a simple drag-and-drop process, the HR units appear as an external hard drive when you connect them to your computer) but you can’t unfortunately select loops from the library using your feet - you have to use the touch screen for that, so that’s a lot of bending down to access the screen if you’re playing live)
The Practice Tool however is a really good option; you drag sound files (mp3/wav etc) in to the Practice Tools folder when you’re connected to a computer, and then they appear on the Core/Prime when you access the Practice Tool (and you can assign a footswitch to access the Practice Tool)
Then you can play/stop the files (and also do a lot of other things like fast forward/rewind etc) with footswitches but the best feature, from a live performance pov is that you can select the next or previous track, using f/switches, so you don’t have to bend down. This makes these units really useful if you’re a solo or duo act, and want backing or drum/bass tracks as you can load these to either a USB stick, on to the device itself, or just stream them from your phone/table at the HR units have Bluetooth.
This is the kind of features I’d really like to see NDSP add to the QC, but as I said, nothing happens quickly…
If you take a look here, you can see my feature request for saving loops…
