I’m new to the digital recording and plugin world… I bought the Plini and Nolly, installed it and Logic Pro X… Now how do I record my plugins in Logic?
Help
Help
Hi @mark-2076. Recording in Logic is pretty straight-forward when you know where to look.
Take a look at the top left corner in the DAW window. If you click on the “?” icon, you will see a little description when you put your mouse pointer over any place. Give it a try!
Setting up your recording session really boils down to a couple of steps:
Audio FX Slots :
If you can’t hear your instrument, make sure you have enabled the input monitoring on your track and in Logic itself.
Track :
Logic :
You can enable your input monitoring in the " Record" dropdown menu as well.
This can also help you: Logic Pro X manual.
