New QC owner, pardon my naivety but is there a difference between using Input 1 vs. Inputs 1/2 at the start of the signal chain?
Normally I have 2 guitars plugged directly into the unit and would love to be able to swap between with no adjustments made to the overall presets/scenes. I do notice however signal is slightly clearer with small increase in volume when using only input 1 vs. inputs 1/2.
This simply means that you are using one input (input 1) versus two inputs (input 1/2). You can plug two separate instruments into the QC this way, which can be helpful for some situations.
Thanks for the reply. What I’m experiencing is actually an apparent gain boost when selecting ONLY Inputs 1 or 2 vs. inputs 1/2. All my I/O settings are at default for all inputs - which is odd.
