I would like to be able to see if a block, which has the bypass assigned to an expression pedal toe switch / an external footswitch wired to an exp input, is active or bypassed while gig view is opened in scene mode.
Currently it’s not possible to know if the corresponding block is engaged or bypassed while in gig view (scene mode). For live use that’s really unfortunate: If I did not hit the switch fully because of a dark stage, the hectic of a live performance, or just because of being clumsy, I will not know and fuck up the upcoming part of the song soundwise… Two GUI indicators will make this more resilient against mishaps ![]()
Only two other people in here that use the exp inputs for bypass switching blocks? I need this feature
It’s super nerve-wracking to not being able to tell if a certain block (e.g. a pitch shifter) is bypassed or active when controlled by an external exp switch. I use the toe switch of my exp pedal for this and every single time I’m nervous because I can’t see in which state the block is before starting the song… please neural don’t do this to my heart any longer ![]()
