Not sure why it’s not there but it is essential to be able to toggle the bypass on a pedal as you are setting levels and checking tones.
Still driving me nuts. Pressed my EQ and and wanted to turn it on (dont have it assigned to switch) but I can’t, I have to switch to scene mode, turn it on, and then go back to stomp mode. Seems totally unnecessary. Should be a bypass on every block all the time, no matter what mode you are in.
I’ve noticed this too. Each block should have a BYPASS button in the parameter menu (when you touch on the block).
