In addition to the usual commands for changing presets, scenes, turning on / off effects, and changing various parameters, a few specific actions would be extremely useful and in demand:
- Mute all sound
- Mute all stereopath (Leave sound from PC. This is required, for example, to mute the connected microphones and continue to use the device as soundcard)
- Mute selectively each channel of the device
- Level controls for all inputs and outputs
- Duplication of controls, including built-in expression pedals (when receiving a MIDI message, QС should react as if the user pressed or turned the built-in hardware controls, that is, the same message can trigger different actions depending on the context)
