I want to capture the BOSS DS-1, how do I connect it to the Quad Cortex?
I’ve searched the manual and YouTube, but I don’t understand, so I’m asking here.
Is it possible to directly capture a normal pedal like the Boss Ds-1? (Is it possible to connect directly without an actual amp or DI?)
Where should I connect the DS-1 INPUT/ouput to the quad cortex?
Just start the capture process and follow the instructions (also covered in detail within the manual) Also, you would capture a drive pedal using the same process as capturing an amp etc.
I know I’ve seen Pete Thorn and Rabea do a demo of capturing a pedal on YouTube. Should be quite easy to find them or a bunch of others going through the process. Also check the user manual for info. And the QC guides you step by step anyway.
